what does your car idle at?
LS1Tech Administrator
Received 1,486 Likes
All LS1 years M6 are set to 800rpm idle.
All LS1 years A4 are set to 650 park/neutral, 550 in gear.
The stock tachs aren't perfect, so you may see different readings on the gage. A scanner is the only way to tell for sure if the car is idling at the proper RPM.
yeah, i guess this could be the case.
too bad i cant afford a scanner (unless they make a cheaper one that i can look teh idle up)
very true, my does about the same. cold idle can be from 1200-800 for me, but thats REALLY cold
My M6 idles at 1100 WARM and about 1300 COLD. But when I had a smog test and the scanner was hooked up, the computer said about 800 rpm WARM idle.
So my factory tach is off about 300 RPMs.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by TORCHD 02 TA
My M6 idles at 500 - 600 RPMs
