Fueling & Injection - No Fuel Cyl 1,3,5,7
View Full Version : No Fuel Cyl 1,3,5,7
1sick'98WS6
11-05-2006, 04:39 PM
So i had a head gasket leak and just got done putting the head back on and everything is back together... For some reason just one of the banks is not getiting any fuel. All the spark plugs are white. What could this be? a ground on the back of the head, i just checked all those.What would cause those injectors to not get power
ou812/z28
11-05-2006, 04:54 PM
check and see if the coils r firing on that side .....if not check the 7.5 amp fuse in the fuse box drivers front for that bank...
V6 Bird
11-05-2006, 08:47 PM
check and see if the coils r firing on that side .....if not check the 7.5 amp fuse in the fuse box drivers front for that bank...blown fuse, injectors not snapped down etc,,,
1sick'98WS6
11-05-2006, 09:35 PM
Thanks ill check that out tonight... Any more ideas out there?
distortion_69
11-05-2006, 10:11 PM
Check the harness for the injectors, make sure it didn't get pinched in the valve cover and cut.. or to make sure its connected good. Been there with experience (check sig.. that was the misfire, lol)
Later,
Josh
1sick'98WS6
11-05-2006, 10:18 PM
The connection for all fuel injectors... where would that be, they are all plugged in if thats what you mean, Its just wierd because they were working fine before i took the head back off
1sick'98WS6
11-06-2006, 03:40 PM
Btw i recently did a motor mount on driver's side.. could it be one of those grounds
notatruews6
11-06-2006, 04:31 PM
It sounds like you have a blown injection fuse, check the cover for which fuse goes to the injectors, there should be 2 banks one for each side of the motor.
ls1_doc
11-06-2006, 04:42 PM
Yeah i would bet on the fuse as well. We just had this same problem on a car we did a motor swap on.
1sick'98WS6
11-07-2006, 11:24 PM
both fuses look good though..ah this is really bugging me
distortion_69
11-08-2006, 01:03 AM
Are the injectors getting voltage?
Josh
LSGunZ28
11-08-2006, 01:12 AM
couldnt it be a restriction of the fuel rails on the drivers side bank? vs a fuse or electrical problem?
1sick'98WS6
11-11-2006, 01:55 PM
could a vacuum leak on that bank cause this problem?
