Generation IV Internal Engine - LS2 to LS7 conversion kit?
Camaro_Guy
11-05-2006, 05:49 PM
Does such a thing exist? I guy I know claims that he put a LS2 with an LS7 conversion kit in his truck. To my knowlege the LS7 is a completely different block from the LS2.
Ferocity02
11-05-2006, 07:05 PM
Yes, the blocks are different to some extent. I'm not sure what a conversion kit would entail, besides an entire engine swap!
LS2 Pontiac GTO
11-05-2006, 08:10 PM
The LS2 is a 4" bore and the LS7 is a 4.25" bore. LS7 heads will not fit on a ls2. However ETP makes a small bore LS7 head that will fit a 4" bore.
Quickin
11-05-2006, 08:26 PM
LS7 is a 4.125 bore. Probably missed the "1" key. The LS7 heads will fit any type LS? engine, just gotta have the right machining done (ie: pistons). They will just work better with a bigger bore.
LS2 Pontiac GTO
11-05-2006, 08:27 PM
LS7 is a 4.125 bore. Probably missed the "1" key. The LS7 heads will fit any type LS? engine, just gotta have the right machining done. They will just work better with a bigger bore.
opps missed one key :bang: , thanks for the correction.
Yeah the heads can fit any LSx block, I just assumed he was talking about stock bore size.
Camaro_Guy
11-05-2006, 08:38 PM
I have no idea what if anything is done to his truck. What he said was he swapped a LS2 motor with a LS7 conversion kit into it. I've never heard of heard of anything like that.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
