Water pump question??
While removing my WP today I had a little problem I removed the top bolts first but when I removed the driver side middle bolt the rest of my coolant in the block poured out the bolt hole. does this sound like a problem??
heck no those bolt are not sealed i took my off it did the same thing no problem cause when u bolt it back up and seal and bolt it on it won't leak! Those bolts go into the block so it is all right!
