T88 FM and a 370CI.....do you have this combo?
Old 11-07-2006, 05:50 PM
Mr_president's Avatar
Default T88 FM and a 370CI.....do you have this combo?
so i was curious how many guys are running a t88 and a 370 6.0 motor? what is your fully boosted rpms and how much power did you make?
t76 guys if you want to post as well remember im only asking for 370 CI motors and t76 or t88 numbers on pump gas and race gas or meth thanks guys
Old 11-07-2006, 06:13 PM
LS1TECH Sponsor
DrTurbo's Avatar
Talk to Nasty_TA he has a 370 ci engine and had had both the 76mm and 88mm on the same setup. He ended up with an S88 which kicked the crap out of a GT42-76.
Old 11-07-2006, 06:16 PM
yea when i was researching i saw that he had a 370 and a t88.....had somewhere around 8xx hp
Old 11-07-2006, 06:31 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yeah he that at just 17psi or so
Old 11-08-2006, 08:51 AM
Josh@KY-Turbo's Avatar
I will have a T76 on my 00 Z28 shop car soon. It has a 8.5:1 370 with ported and polished 6.0L heads. I will post up results when I get it finished. Hopefully this month is all goes as planned.
Old 11-08-2006, 09:46 AM
smokinHawk's Avatar
only a 347 cubed ls1 8.9:1 CR, but with a PTE88
sees 12psi about 4000-4200, 15psi a little over 4200
making around 700rwhp through an M6 with 15psi, about 620rwhp with 12psi (going by trap and weight)
should be making a bit more next season since i finally got 3bar setup and some 96lb injectors and then gonna boost past 20psi
Old 11-08-2006, 09:48 AM
NA$TY-TA's Avatar
Yeah i have a T6 Flanged 88....
Made 842rwhp thru a Glide and a 12 bolt..@ 17 psi.
My 9.26 pass was on 20 psi.....
I drive the car around on 14 psi everyday....Pump 93...
I start seeing boost a lil over 2k and my 4k im at full boost.....
I love the combo......
On the transbrake i can get 10psi before 4k
Kyle
Old 11-08-2006, 10:25 AM
LS1TECH Sponsor
DrTurbo's Avatar
The S series units truly are a beast.....your combo sounds awesome for the street as well.
Quick Reply: T88 FM and a 370CI.....do you have this combo?
