T-rex in a 04 z06 question
Old 11-07-2006, 05:50 PM
blackls6's Avatar
Default T-rex in a 04 z06 question
Yeah I was wondering, if I ran the t-rex cam in my z06 with the stock ls6 heads would I need to flycut my pistons? Also, how low of a LSA could I run? Thanks.
Old 11-07-2006, 06:22 PM
blackls6's Avatar
Old 11-07-2006, 06:58 PM
blackls6's Avatar
Old 11-07-2006, 07:40 PM
02BLKWS6MD's Avatar
I don't think you have too, if its just gonna be installing the cam only. If it had milled heads being put on then you would have to flycut the pistons I believe.
Old 11-07-2006, 08:43 PM
blackls6's Avatar
Yeah thats what I was thinking. Anyone else? Also, whats the lowest lsa I could run?
Old 11-07-2006, 08:46 PM
pianoprodigy's Avatar
The T-Rex only has one LSA, like 109 IIRC.
Old 11-07-2006, 08:49 PM
SSilverSSurfer's Avatar
why dod you want to go with a even lower lsa than what it comes?
Old 11-07-2006, 09:15 PM
ls1muscle's Avatar
Don't forget that the LS6 heads you have are 64.45 cc vs. the LS1's 66.67, so that's like milling an LS1 head .015
Old 11-08-2006, 08:26 AM
STL2SLO's Avatar
I would call Thunder and ask them to make sure. They could tell you.
Old 11-08-2006, 08:46 AM
Studytime's Avatar
If I'm not mistaken, this is mis-information. Remember how the 5.3L head has better PTV clearance, the LS6 head is the same. The chamber is reshaped not milled.
Also, I wouldn't change the LSA. Probably whatever you're thinking was tried in a test car when the TRex was being developed.
Ben T.
Old 11-08-2006, 08:59 AM
Cam02ss's Avatar
t rex is a 110 lsa
Old 11-08-2006, 09:37 AM
blackls6's Avatar
Ok thanks. I was thinking that I might get better torque if I went went something lower than a 110lsa? Then I might have piston to valve clearance I suppose. Thanks for the help guys.
Old 11-08-2006, 10:10 AM
Kraest's Avatar
That's going to ruin the Corvette. IMO, big stupid cams and loud exhausts ruin the Y-body. I had a big cam and loud *** exhaust in my old C5, and I think it was the wrong "style" for a Vette if you get my drift. Granted, the cam-only put down 415 rwhp through a stock TB, LS6 intake, and no underdrive pulley and heads/cam put down 471 rwhp, but it would be like putting whorish clothes on a classy chick.
With that cam, you're going to make complete **** low-end and need at least a 4.10 gear.
Old 11-08-2006, 10:30 AM
Cam02ss's Avatar
with a t rex you're going to beed 4.30s if you're 6 speed
Old 11-08-2006, 11:49 AM
blackls6's Avatar
**** it. I am going to get the T-rex and run it with my stock gears. I have a ms3 now and it seems kinda mild to me. Thanks for the help though guys. The T-rex will make more power under the curve from what I have heard.
Old 11-08-2006, 11:57 AM
Mcduffys's Avatar
There is quite a difference in the MS3 and T-Rex. The T-Rex can be plenty streetable if you want it to be. Its all in the tune. But i would defintely get a set of 3.90's to make up for the low end your going to lose.
The T-Rex on stock gearing would be fairly sluggish down low, but A properly tuned T-Rex + 3.90s on a 3200lb car will be xtremely fast.
Old 11-08-2006, 12:19 PM
2000 Tran Zam's Avatar
XXXtremely
Make sure they flycut your pistons though, otherwise your gonna be in a world of hurt, lol.
Old 11-08-2006, 12:23 PM
Originally Posted by 2000 Tran Zam
XXXtremely
On second thought, I would just make sure to check the piston to valve clearence just to be safe.
Old 11-08-2006, 12:25 PM
Whats wrong with running a big cam in a vette? Its equally as intimidating to have a loping vette as it is for an f body.
Whats the point of getting a vette if your gonna drive it like your having a mid life crisis?
Unless you prefer more tq down low, why not
Old 11-08-2006, 12:26 PM
Cam02ss's Avatar
look man, i agree...the t rex can be streetable; it's all in the tune. but what was said above is also correct..it's going to be sluggish down low..especially w/ stock gears. hell mine was sluggish even w/ 4.10s. go the extra mile, put 4.30s in your vette and it will be one bad mother. there is a world of difference between the ms3 and t rex.
Quick Reply: T-rex in a 04 z06 question
