ls1 347 vs 5.3L ?
Old 11-07-2006, 07:33 PM
2ktransam's Avatar
Default ls1 347 vs 5.3L ?
I have my ls1 from my TA sitting in my garage and it has me thinking. I want to start modding my truck which is a 01 Silverado with a 5.3L and I was thinking of swapping out the 5.3L for the Ls1. I daily drive my truck and pull with from time to time so I am going to go with a smaller cam like a tr220 and a small stall close to 3000. My question is how much more power will the ls1 make compared to the 5.3L assuming that they will have the same supporting mods. I plan on getting headers and a cutout but I am going to leave the intake and tb stock. I already have stage 2 heads sitting on my ls1 but if I stick with the 5.3L I will sell them and buy stage 2 5.3L heads. What do you guys think? Is it worth going through the trouble of swapping out the short block? I would be doing the swap myself by the way.
Old 11-08-2006, 02:09 AM
RomulusSmallBlock's Avatar
bigger is better.
Old 11-08-2006, 02:19 AM
bww3588's Avatar
not neccessilarly. do you have the LM7 or the L33 in your truck? if you have the L33 your have 310 rated hp. whth some bolt ons you can have more power than the LS1 can provide. however if you have the LM7 you have 285 hp. the basic difference between an LM7 and an L33 is the block which is almuminm on the L33 and iron on the LM7. the L33 has higher comp. ratio for more power. if you have the L33 in stock form and your LS1 is in stock form, the LS1 will make about 40 more HP than the L33. if you have the LM7 the LS1 may be a better idea. but for the money, i would just cam your L33 and sell the LS1 for money to buy parts.
edit: now that i have re read your post, the only way i would swap out the short block is if you have the iron block LM7. other than that i would put the stage 2 5.3 heads and the other stuff you have including cam and call it a day. its all gen III engine stuff so it will all coexist.
Old 11-08-2006, 04:36 AM
Lurius's Avatar
If its an 01 truck the engine is rated, I think at 285hp.
-Lurius
Old 11-08-2006, 09:18 PM
2ktransam's Avatar
I do have the LM7 engine that is rated at 285. I didn't even think about the weight difference with these two motors. Anybody have an idea what the weight difference is between the Ls1 and the Lm7?
Old 11-08-2006, 10:10 PM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
5.3 is 70-80lbs heavier
Old 11-08-2006, 10:26 PM
2001CamaroGuy's Avatar
5.3 is smaller than 5.7
that right there should be enough to point to which one makes more power (CIs people.....)...
then to top it off, the iron block is ~80lbs heavier.....
Old 11-09-2006, 07:47 PM
mikep2002's Avatar
I think you should put a cage in the T/A and go racing!!!!!
Old 11-09-2006, 07:51 PM
2ktransam's Avatar
What's up Mike? I did buy a 6 point roll bar but I haven't had time to put it in yet. I will have the TA ready to race in the spring and hopefully I can pick up a car trailer by then as well. I think it would be cool if I can roll my car off the trailer and run 10's and then unhook the trailer and run 13's in my truck.
Old 06-13-2013, 10:51 AM
Bankroll Bullies's Avatar
What about the LM4? Any info on it. It just looking for 350-400hp. I can get an LM4 for cheap ($400) but can also get a LQ9 for $1200. Just wondering which one will make the power I want for the cheapest price. I already have an LS2 cam, LS2 rods, and LS6 springs. I will probably go with an LS1 or LS2 intake, fuel rail, and injectors....unless someone knows of a better manifold to use (other than the LS6...to much $).
Old 06-14-2013, 05:33 PM
gagliano7's Avatar
For the truck i would go with the LQ9 over the LM4 because the torque will get that truck moving.
Old 06-14-2013, 07:07 PM
Blackpanther99's Avatar
Iron block in a heavy truck is the way to go.
Old 06-14-2013, 09:36 PM
2nd Gen Fl 'bird's Avatar
And you should search the sticky at the top of this section.
Old 06-14-2013, 10:33 PM
01_SuperSlow's Avatar
Wow, talk about a thread revival!
I have an 01 Silverado with the LM7 5.3 as well. About 207k miles and still chugging along with no complaints .
When it gives up, I plan on going with something like this:
http://thompsonmotorsports.net/onlin...products_id=44
and topping it off with some 243 heads and a LS6 cam or similar.
Old 06-15-2013, 09:07 AM
2ktransam's Avatar
Wow 7 year old thread. I decided not to go with a ls1. My truck now has a forged 370 with a pt7675 making north of 750rwhp. Forced induction is the only way to go on these heavy trucks.
Quick Reply: ls1 347 vs 5.3L ?
