Drag Racing Tech - will removing the plastic below the radiator increase MPH in 1/4?
Houston999
11-08-2006, 12:28 AM
will removing the plastic below the radiator(that helps to reflect air to the radiator) increase MPH in 1/4?and yes it is a race only car.
94z28L
11-08-2006, 12:44 AM
i wouldnt think that it would make enough of a difference to warrant it, depending on the set up (FI, N2O or NA) couldnt it be possible that a temp increase due to that no longer being there could possibly cause detonation?
V6 Bird
11-08-2006, 07:11 AM
will removing the plastic below the radiator(that helps to reflect air to the radiator) increase MPH in 1/4?and yes it is a race only car.DONT KNOW...BUT IT DOES HAVE ALOT TO DO WITH COOLING THE RADIATOR....
GIZMO
11-08-2006, 07:48 AM
I don't run the deflector because it can false trigger the beams on the top end. I didn't notice any MPH gains, but my cars don't MPH that much anyway (10.5's @ 122-23 mph) I have never had any problems with temperature, but I do run my fans manually.
Daren
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
