Starter wires???
Originally Posted by charlie c5
On a 2000 C5, what are the wires on the starter. I know one is the ground on one post. There is the power from the batter on the other post, so what other wires are there.?
I got that, the small purple going to the small post, the ground heavy wire from the big post into the starter itself. And the large red wire going to the other big post, but I have two other small wires going to that same post... What are they for..?
Thanks man. I appreciate your responce in this. Now can you help me with my stalling problem???? PM me if you can..
Originally Posted by GOaT Cheese
They are just fusible links for charging/volatile memory. All the wires with large "eyelet" terminals go on the same post as the main battery cable. The only other wire is the small purple wire, and it goes on the small post by itself.
Originally Posted by ArcticZ28
Volatile memory in a starter?
Fusible links that provide constant battery power to certain components, some of which contain volatile memory. the main post on the starter is simply a convenient place to pick up 12V instead of having 10 seperate wires going to the positive post on the battery. But you already knew that didn't you?
