down sides to a big cam
Old 11-09-2006, 11:21 AM
DropTopFireChKn's Avatar
Default down sides to a big cam
if i go with a custom cam for my 355 build that's similar to the 847 what would be some of the downsides to having such a big cam? say if i wanted to drive a 3-4 days a week and at times in heavy stop and go traffic
Old 11-09-2006, 11:31 AM
LT1nitrouZ's Avatar
is this a trick question? are there downsides to a big cam? umm only things I can think of are the following.
less vacuum for brakes... shouldnt have much of a problem with that size cam though.
Rough Idle... who phuckin cares?
Higher RPM's... little less reliability if you have a power band that goes to 6900... once again who phuckin cares?
Will need a good tune... your gonna have to have that anyway.
Old 11-09-2006, 11:32 AM
Ls1Bait's Avatar
Gas mileage, drivability. But with good tuning you shouldnt have a problem. Thats why EFI is nice I have a pretty big cam and and tune mine myself and it drives perfect.
Old 11-09-2006, 11:36 AM
ya i already knew those that you mentioned and i'm going to get a vacuum canister, rough idle?! lol i ****** love that sound, higher rpm's? it's going to be fully forged andd i only plan to spin it to 6500 or so.. what i'm concerened about is if it will be really hard to drive for some reason or if it will have a tendancy to die on me or something at idle...
Old 11-09-2006, 11:49 AM
LT1nitrouZ's Avatar
that would be the reason for a good tune.... like I said... is this a trick question? I figure something like a solid roller 256/264 on a 108 would be nice
Old 11-09-2006, 11:54 AM
Ls1Bait's Avatar
Yea I run a vacum canister.
Old 11-09-2006, 12:02 PM
DroppedM6Z's Avatar
i'm using the 847 on my forged, LE2 355......it should be nasty w/ my 3.92's and the 9"
Old 11-09-2006, 12:07 PM
redneck01's Avatar
get a custom cam on a tighter or smaller LSA and use a little more duration with modest lift. FE: Try a cam thats about 23x/24x on a 111 lsa (hydraulic)...that way you're pulling from about 3k-6600 and have a decently lopey idle. If you want it to idle smoother..increase the lobe separation to like 114.
Just save the time and energy and get a custom grind..thats the best option these days.
Old 11-09-2006, 12:23 PM
I Plan To Get Something Around 111-112lsa But I Guess My Question Is How Exactly Does It Affect Driveability?
Old 11-09-2006, 12:56 PM
LT1nitrouZ's Avatar
Idle, gas mileage, and less vacuum or the only things that affect drivability. All things can be compensated for though.
Quick Reply: down sides to a big cam
