Fog Lamp
Originally Posted by 09CPTN
How do I change the bub in the right side fog lamp on my 98 T/A? The owner's manual doesn't say. Thanks!
go under the car, there are 3 body pins that need to come off. i take them off with a tiny flat head screw driver and pry them down. then once you get the 3 body pins off there are 2 10mm bolts holding the fog ligh thousing in place. take the 2 bolts off, you will have slack to get the wiring off th efog light and be able to pull the fog light out.. Very easy. took me about 5 mins each side..
Doubt it. I'm 6'5", 220lb. and I have huge hands. It's a little tight to get your hand down there, but once it's in it eliminates a lot of the fog light changing hassle. No unbolting anything, just be careful getting your hand in and out.
i perfer to do it form underneath the car.. JMO
