Sponsored by: DashLynx
rear wheel wells
Old 11-09-2006, 07:34 PM
Blown Ta's Avatar
Default rear wheel wells
hi guys, what can i use to paint/coat my wheels wells?
they are all faded, and some of the coating is falling off.
just wanted to make it look new and shiny again.
thanks
Old 11-09-2006, 07:41 PM
ZaneO's Avatar
POR-15 or Eastwood Suspension Black.
Old 11-09-2006, 07:45 PM
DaddySS's Avatar
I used Duplicolor truck bed liner spray. It goes on easily and really lasts plus it is super easy to keep clean.
Old 11-10-2006, 07:28 PM
Man-Crush Warning
01sscam's Avatar
rubberized undercoating spray.
Old 11-10-2006, 08:30 PM
CAMAROZ28AQUINO's Avatar
......+1, make sure it hardens because there is some stuff out there that does not and makes a mess
Old 11-11-2006, 02:00 AM
Silver02TA's Avatar
+2 ... from 3M
Old 11-11-2006, 02:10 AM
MJK
MJK's Avatar
Any of you guys have any before and after pics?
Well...I know what they look like before,but....
Old 11-11-2006, 02:47 AM
Mike00ss's Avatar
Yea I’m interested in seeing these pics as well.
Old 11-11-2006, 03:40 AM
6LITEREATER's Avatar
I just spray mine with a Dupli-Color low-gloss black... Not sure I see the need let alone understand the reasoning behind spraying a rubber coating on plastic
Old 11-11-2006, 04:15 AM
02wS6firechicken's Avatar
Go with the rubberized undercoating. Cheap enough that when it dulls out in 6-8 months you can just apply another coat. It made my wheel wells look 10 times better. I used the stuff from my dealership, it comes in a quart jug and you use a spray gun with shop air(pretty technical name i know) to apply it. I had enough to do each wheel well twice and a good portion of the underside of my car. I havn't used the 3M aerosol but I think its pretty cheap. I sprayed overtop the plastic fenderwells and everything. When I wash, I just run my mit on the inside of the wells to scrub the dust off(gravel road ). Then I take some foaming tire shine and coat the wells. After it drys they look amazing and there is no dull black look like you have now. Plus when the wheel wells are all black it doesn't take away from whatever wheels you have and makes them look better too.
Old 11-11-2006, 04:23 AM
Not the best quality but see what I mean about not taking anything from the wheels. I can Get some close ups of the wheel wells after detailing if you want.
Old 11-11-2006, 06:19 PM
SpdFrk1990's Avatar
Truck bed liner is by far the best thing you can use it even comes in a spray can. If you want you can take a torch and scrape off the old undercoating first just becareful of the paint and it will hold much better. This will not flake or chip off.
Old 11-11-2006, 09:51 PM
EvilBLK02TA's Avatar
I never thought of that! Good idea!
Quick Reply: rear wheel wells
