Need some advice !!!
Ok. im planing on doing a tune-up on my 96 z28..i have bought all the parts needed and want to get them installed at a local auto shop.I have bought msd cap/rotor,msd wires,ngk tr55 plugs,felpro header gaskets(because the driver side gasket is screwed because of header leak and figured id go ahead and replace both sides)and donut gaskets. I called the auto shop to get an estimate on what it would cost and was expecting around $700-$800.. ...Well...the lady called back 15 minuites later and said it would cost $1050.00!!!!! and thats with me buying the parts!!!! screw that!!!!I hear this shop is really good though...do u guys think its worth it?
.....Thx
.....Thx
dude the opti is easy all you have to do is is drain coolant, remove air pump, remove water pump, and the damn opti is right friggin there its a total piece of cake sure it takes a little time but its nothing more than a six pack of beers worth
definately get on some of the local forums and tell some of those guys if they come to help you out if you need it that you'll provide pizza and beer or something (and actually do it) and you'll have no problem gettin some help
You should try and do it yourself. Like 1994Z28LT1 said, it's easy. I would try it as a learning experience. If I was close to you I'd help you out. On a level from 1-5 I'd say its about a 2. Just get yourself a manual, and take your time on it. Good Luck
Definitely a pain but, like they say, Its only the time consuming part to get other pieces and accessories out of the way first.
But think, take that money you save and get headers and exhaust! Or, take the $850 you were planning on spending and convert to delteq (assuming the optical pickup is fine and its just the distributer thats messed up).
Originally Posted by infinitebird
That price is really not all that high for a shop quote on that work. I've seen higher.
It's still too much but all that work does take a fair amount of time.
Like said, just do it yourself and save the $. It's not all that difficult. Just need some patience.
If I remember correctly when I got a quote for my own entertainment one time, a shop told me the computer said 8 hours for the plugs and wires alone -- so that should give you an idea what a full tune up on an LT1 will cost. Its not cheap. Learning to do basic maint. on your car not only saves money, but it helps you get more confident when working on your car and tackle larger projects farther down the road. The only real thing you must have when doing any of that stuff is patience. Take a deep breath, take your time. Do it once and do it right. If you have to walk away from it for 10 mins to cool back down before starting back on it, do it. Also, don't be afraid to ask or use the search function. This forum is a great resource.
Originally Posted by WhyHelloOfficer
Agreed. The labor hours that are in the computer for a 'tune-up' for an LT1 is pretty high.
a few beers will help keep you relaxed too, just not too many
