Clutch install gone wrong, no oil pressure.
I guess you could say this is the worst clutch install ever. After pulling the transmission for the second time after I found out I had a bad clutch I did my regular routine that I do to a SBC. I take pieces of newspaper and dip them in water to pound in the back of the crankshaft to drive the pilot bushing out. After the pilot pushing falls out i take the paper out and I soon find out that the LS1 has a freeze plug in the middle of the crankshaft??? I was able to get the freeze plug out which was pressed against a rod end crooked with part of the bottom end exposed. I wasn't sure or not if any paper got through so I took my chances and reinstalled the freeze plug, pilot bushing, clutch, tranny etc. I'm testing the car out keeping a close eye on the oil pressure to make sure its not dropping and about 1/2 mile out cruising at normal rpm's the oil pressure starts to drop. Before it hits zero I shut the car off going 40mph and coasted my way into a subdivision. Just to make sure my mind wasnt playing trick on me I tried starting it for a second and sure enough the oil pressure gauge didnt make it out of the red (only for a second or two). I obviously think a piece of newspaper is clogging the oil pickup but I wanted some input as to what other problems you think this may have caused?
I assume since you re-installed the freeze plug, that oil leaking isn't a problem. If you really feel that you only ran a few seconds, then I'd say you might be able to get all the paper off the screen of the pickup. You'll want to check thoroughly to see if more made it into the pump. If it did, you've got a mess on your hands.
Next time try using a blind hole puller from Autozone to get your pilot bushing out. Then there is no need to force stuff behind the bushing to push it out. And it works like a champ too.
Originally Posted by csmc711
have you been working on cars for a long time???
chris
Thanks for the responses!
I don't know where your going with this csmc711 but it doesn't sound welcome. I probably have more experience than you and I am not the least bit emberessed by my mistake. This is the first hollow crankshaft I have seen.
Still going through it with dentist tools trying to find anything i can get ahold of. I think i got everything out that was in there. Started working on it 5 hours ago and am starting to re-assemble.
Originally Posted by CamTom12
Good to hear it wasn't a huge issue. It's running with full pressure now?
No, you dont, cause you would have KNOWN that was the issue.
You also need to learn english, let me give you an example:
IROCSS "I dont know if this is a poke at rodrigues or not"
My responce "uhm..................no"
how hard is that to figure out? If I wanted to be a dick, I would have said probably as hard as you figuring out what was wrong with your car.
I was defending and supporting you, back off!!
Oh, glad to see that was all it was.
You too, hugh? Okay, let me spell it out for you!
Who was above my post "have you been working on cars for a long time???"
Check it out and get back to me, I will be here paitiantly smoking my ciggarette.
It doesn't matter... 60psi oil pressure at startup, everything is good.
awesome. good save by paying attention and shutting it down quickly. and damn, I wish I had the initiative (SP?) to be out there working in all my freetime.
BTW Pat, how's your 95 been running? I thought I heard of you running at M11 this year and getting into the 9's? that right?
what I dont like is how big the pickup is. What genius thought a 1"x2" screen was good enough? If crap starts to float around in there, its gonna clog quick! The old style screen/pickup worked great, I want to see GM's tech artical as to why they changed!?
I am starting to see why there are so many problems with the LS1 engines bearings. I took apart a 45k motor and not the best looking bearings in there, but, I have t admit the screen wasnt clogged : / . I really do not think there is enough surface area to suck up all the needed oil. I need a hydrolic flowoligist to chime in .
