Drag Racing Tech
Will a 28X10.5 tire fit in my car?
Old 11-10-2006, 03:17 PM
02Z28's Avatar
Default Will a 28X10.5 tire fit in my car?
Car has a 12-bolt narrowed 3 inches on each side, SJM adjustable LCA's, and I just got my 15x9.75 Bogarts with 5 3/8" B/S. Do you guys think I will have to mini-tub the car to get the tires to fit? Or should I go with a smaller tire?
Old 11-10-2006, 05:38 PM
94z28L's Avatar
should be fine as long as the backspace is correct for the rear
Old 11-10-2006, 08:41 PM
Tonyss1's Avatar
Default 28x10.5-15s
Rear narrowed 6 inches
15x10 rears 5 inches of back spacing wheel wells are massaged a bit no mini tubs.
go to bottom of page to get the latest pics of the car. 2006
http://pg.photos.yahoo.com/ph/pezzin.../ph//my_photos
Old 11-12-2006, 12:19 PM
gator's 99TA's Avatar
it will fit with minor banging on the wheelhousing area. no different than a stock wheel/rear assembly.
i narrowed mine 3" on each side and run a 5.5BS wheel with a 13" wide tire. i had to cut up but a 10.5" slicks (non w) will fit easily. in fact, you might not even need to bang much at al
Old 11-12-2006, 06:30 PM
02Z28's Avatar
Awsome! Thanks guys for the help.
