ss3600 highway rpm ?
Old 11-10-2006, 10:21 PM
nikon1999's Avatar
Default ss3600 highway rpm ?
question for everyone, not sure if the lock-up on my converter is working properly or not. Those with a yank ss3600, 3.73 gears and a stock diameter tire, where are your rpms at @ 70mph. Thanks
Old 11-10-2006, 11:39 PM
c0ncEpT's Avatar
Well if the converter is locked up it shouldent make a difference what converter anyone else has as long as its a lock up converter. The gear calc says 2400 at 70 in 4th with a 3.73
Old 11-10-2006, 11:52 PM
Magnet's Avatar
thats what hes trying to find out...if its locking properly...
Old 11-11-2006, 09:17 AM
losiguy's Avatar
I have the exact same setup, its probably 2600-2800...it goes up and down easily with the slightest touch of the gas, I would lean more towards 2800. I get very bad mileage on the highway.
Chad
Old 11-11-2006, 10:58 AM
AK's WS6's Avatar
Yeah, if it's not fully locking it should be pretty obvious, like losiguy said the RPM's will rise quickly if you just tap the gas and it will be loud!!
Old 11-11-2006, 12:12 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
3000 @ 80 mph with 3.73s.
Old 11-11-2006, 12:26 PM
losiguy's Avatar
Sounds about right, 3000-3100. Its hard to make it exact ecause at that speed the slightest touch of the gas with the 3600 stall makes rpm's vary alot.
Also is very loud with a dumped exhaust.
Old 11-11-2006, 01:36 PM
BlackHawk T/A's Avatar
The RPM's should barely budge at all if the converter is locked, it is a very tight feeling.
If it is unlocked then yes it will slip and "rev" a little. In that case though you are heating up the transmission pretty bad.
Old 11-11-2006, 01:52 PM
Jpr5690's Avatar
In Other Words.. If Locked Up Your Rpms Should Be The Same As They Were Before The Converter....
Really Though Just Lisen And Feel For The Lockup.. I Know In My Car I Can Feel And Count The Shifts And Feel The Lockup.. Or Even Just Wath The Tach.. (once Your In 4th And Holding The Throddle Constant If The Rpms Drop Again It Is The Converter Locking)
Old 11-11-2006, 02:50 PM
nikon1999's Avatar
yeah thats why i think its not locking ,i mean my rpms sound similiar to everybodys, but i swear i have to be doing 75-80 to get it to lock up. Doing 70mph and give it a little bit of gas the rpms just climb before gaining speed (i.e - its unlocked) just trying to figure out whats going on..was going to send the converter to yank and have them reflash to a ss4000 but its $275 + shipping I thought you got one free restall w/these?
Old 11-11-2006, 03:09 PM
calongo_SS's Avatar
If it's not locking it should be obvious. A locked converter is like drining a standard with the clutch all the way engaged. If you tap the gas and the rpms go up and the car doesn't go, it's not locked.
Old 11-11-2006, 04:28 PM
I would get your car scanned and logged before you spend a bunch of money getting your converter looked at.
Old 11-11-2006, 04:44 PM
nikon1999's Avatar
yeah i think im going to order hp tuners and figure all this crap out need to fix some idle/surging issues anyways
Old 11-12-2006, 04:29 PM
02white6.0's Avatar
Thats what my car also turns at 80mph with 3.73s and a ss3600.
