tranny problems
tranny problems
turned the car on this morning and everything was ok until my car wouldnt shift to second gear or third, just stays at one all the time. any idea what this could be?
Are you sure it was stuck in first gear? Did it seem to be slipping or maybe stuck in a higher gear? I believe it might have been stuck in limp mode which will be third gear. Any codes or ses lights? If it is stuck in first gear the low roller is locked up or the low and reverse clutch has welded itself together.
