miss/hesitation
Old 11-11-2006, 09:51 AM
silverLS199's Avatar
Default miss/hesitation
car feels like it has a slight miss hesitation around 2-2500 almost all the time im wonderig if its fuel filter or plugs or what any ideas
Old 11-11-2006, 10:27 AM
JDJP's Avatar
I used to have a hesitation when first starting to move, you need to change the plugs/wires, feul filter, air filter, and sea foam it, then go from there, but that worked for me.
Old 11-11-2006, 10:30 AM
sea foam?
Old 11-11-2006, 01:12 PM
JDJP's Avatar
Ok, before you start asking questions, search around on the site a little.
Im sure every question you can think of has been asked at least once.
Do your best to search, then if you don't find anything, start a new thread.
Ill help you out on this one, but if you spend some time on the site, you'll learn a lot.
https://ls1tech.com/forums/showthrea...hlight=seafoam
Good luck
Old 11-11-2006, 06:35 PM
KrazyDan's Avatar
I had something similar. It was an arching spark plug wire
Old 11-11-2006, 08:54 PM
never2low's Avatar
I had the same sort of thing and i ended up putting new injectors in to fix it.
Old 11-12-2006, 08:31 PM
i think im gonna get a new fuel filter as soon as i get my oil changed and do a fuel system cleaner and when i get headers hopefully in a couple weeks i will get plugs/wires is a LS6 intake worth it in anybodys opinion
