Meziere water pump=better E.T.?
Originally Posted by 1999 SS
i noticed that the engine revs up faster. that tells me that the ewp is freeing up some parasitic drag and putting the motor in "power band" quicker.
Im lovin my new pump .
Originally Posted by FBodyPerformer
Whos the guy on here that says in his sig that he gained like 10mpg by putting on the Meizere WP? Is that true?
10 mpg is a pretty strong statement. I do believe it does take about a 3-5% load off the motor, it should equate to much better gas mileage if you do the math. It takes some power to flow water through the narrow ports in the motor to keep it running cool.
Better gas mileage? Yes.
10 mpg? I don't see it.
Would I buy the EWP again? Sure, but not if I needed gears or cam or stall converter. This was my last mod after my motor build. If you need other power/performance producers, I'd do it last.
haha. nice Russ. That probaly looked like when Ron's LT1 dumped its coolant everywhere!
But yea, I know the 10mpg thing is a bit off, But its in someones sig. They got somewhere into the 30mpg range supposidly just by adding the Miezere WP.
