lt4 cam spring
lt4 cam spring
i found a great deal on a set of lt4 cam springs. but im putting a cc 503 or 305 cam in my car and im wondering if these springs will work or do i need to get diffrent ones. thanks
the LT4 hotcam set has 1.6 RR's, and the 503 is compareable size to it.
Originally Posted by sssalah
Those springs will work with both cams only if 1.5 ratio rockers are used. The lift with 1.6 will be too much for them.
The 503 lift with 1.6 would be 0.536"/0.544", 305 is 0.544"/0.544". The LT4 springs were made for the stock LT4 cam which had a lift of 0.498" and they were just suitable for the 0.525" lift of the hotcam.
Hey similar question guys, I have a mostly stock 97 lt1 formula, and i am looking to purchase a lt4 hot cam and the corresponding lt4 valve springs. My question is can the car run well with the stock 1.5 rr's or is it a requirement to move on to the 1.6's?
also are their other necessary mods needed for my lt1 to move well with the new cam and springs, thanks for the help. -D
