short belt question
short belt question
I'm only running the alternator off the crank, but i'm having a problem finding a short enough belt. I can find a 3 rib belt that will fit perfect or I can get a 4 rib one that is a little longer. The4 rib will work if i remake the alternator brackets. Do you all think the 3 rib will be enough since its only running the alternator?
