TH 350/drive shaft
Old 11-12-2006, 06:25 PM
0camaro1's Avatar
Default TH 350/drive shaft
I have a 2001 Z28 m6 car and was wanting to put a 350 with a brake in it. but my ? was do i need to cut the drive shaft or will the factory one be the right size for right now, and i think the out put shafts on a 56 and a 350 are the same size so i could use the factory yoke but im not sure. so any help would be great
Old 11-12-2006, 09:33 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You can use your stock driveshaft as long as the 350 Turbo has a 9" tail housing; so it is a direct bolt in
Old 11-13-2006, 07:12 AM
ss1129's Avatar
But I reccomend against it. It works, I am currently doing this only because Im a cheap ***. It looks to be about an 1" or 2" shorter than I would like it to be. You can get the drive shaft lengthened I think. Yes the factory yoke works.
Old 11-13-2006, 09:51 AM
dhdenney's Avatar
I would get a Denny's Nitrous Ready shaft. He custom builds them so there's no question about fit. The one he built for me is so snug. If you're going to run a brake, then you might need it anyway. It has the 1350 yokes on it and he guarantees it for life.
