Where to get the Porter Cable ???
Wheres the best place to get it from, as far as being the cheapest
I saw that autogeek has it for like 172 bucks. Does anyone else have it for less ???
Im talking about the 7424 just in case. Or should I go with soemthing else ?? I never used one and im a newbie so take that into consideration
Thanks!!!
Thanks!!!
Autodetailingsolutions carries a nice startup kit with the Meg's G100, for around $150 or so, and up, they have several kits ..
doesn't look to me like the sponsor here, Brilex Solutions, carries any type of PC.. but I could be wrong .. might be a good first place to look ..
Originally Posted by ZaneO
You can typically find the PC7336 at Lowes for $99. You would then want a 5" flexible backing plate and an assortment of 6.5" foam pads.
What is different about his Porter Cable ????
And whats better between them two ???
the 7424 and 7336 models are the exact same machine but the 7336 starts life as a grinder so all you do is remove the grinder attachment thing and put a 5" flexible backing plate on and you have a 7424 model. correct me if im wrong?
