LSK Lobe ?'s
Old 11-12-2006, 11:26 PM
hammertime's Avatar
Default LSK Lobe ?'s
I've been reading quite a bit on the LSK lobes offered by Comp Cams. I have a few questions for those who are running them.
How many miles are you driving (average month, for example)?
Have you checked any of the spring rates or free length since installation?
Is there a recommended mileage/time interval for spring replacements?
I drive 3000 - 4000 miles a year, and could probably get 2-3 years on a 10K swap interval, which I have seen posted here before. Although that seems pretty low, I would consider it acceptable. I would hate to change every year, and would probably stay with an XE or XE-R lobe if that is the case.
So, who is running these, and what do you think? Thanks in Advance!
Old 11-12-2006, 11:36 PM
Irocss85's Avatar
I was told by john at TSP that it shouldnt have a problem living 3 years at around 2-3K a year. I also asked him if that spring would have a problem if it see's fewer miles living atleast that long. I dont have the cam in the car yet, but we'll see.
Old 11-13-2006, 11:25 AM
hammertime's Avatar
Thanks for your response - anyone else running these yet?
Old 11-13-2006, 07:50 PM
BlackHawk T/A's Avatar
Had some similar questions.
It's either LSK + Dual spring or XE-R and single spring for me, don't know which way I should go.
Old 11-13-2006, 08:02 PM
ls1muscle's Avatar
I'll be running a LSK lobe (trak), with AFR 8019 springs. Shimming the springs to within .050 of coil bind is important.
Old 11-13-2006, 08:57 PM
Beast96Z's Avatar
The LSk is easier on the valve closing side, wearas the XE-R is a litlle more rough, but the LSK has more lift. I can't see the diffrences in spring life being that much diffrent between the 2. I used the LSK on the intake and a solid profile on the exaust.
Old 11-21-2006, 01:11 PM
hammertime's Avatar
TTT - I know there are more of these out there...
Old 11-21-2006, 01:18 PM
gtovan's Avatar
I've run mine (243/243 LSK) 11k miles as a daily driver since August '05 with no problem. Plan to have springs checked in the next few months.
Old 11-21-2006, 02:29 PM
GuitsBoy's Avatar
rpm and driving habits play a big role too. A spring may last 10 - 15K on the highway. It may weaken up and lose tension after a few K miles worth of drag passes.
Old 11-23-2006, 12:10 AM
LS1 Tech Administrator
Patrick G's Avatar
I put about 1000 miles a month on my daily driver. LSK lobes on intake and exhaust. So far so good.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 11-25-2006, 08:41 AM
MARKSZ71's Avatar
i have a small lsk cam with no problems so far lift is around 620
Quick Reply: LSK Lobe ?'s
