do I need a cam for 3500TC
Old 11-13-2006, 01:18 AM
Mohammed's Avatar
Default do I need a cam for 3500TC
what do you think about running a 3500 stall ?
mods : LT's, lm , shiftkit , lid , tci clutches .
some say you have to install a good camshaft !! I don't know if it's true or not !!
-Do I need a cam ?
-Anything will be wrong if I didn't use a cam ?
I dont want to do something stupid or useless
Old 11-13-2006, 01:30 AM
I8URLS1's Avatar
No... It's usually u need a stall if u get a cam with the autos. Not the other way around. Get the stall and make SURE a trans cooler at the same time. U'll love it man.
Old 11-13-2006, 01:41 AM
jpat1023's Avatar
+1...cam requires stall(normally), Not stall requires cam...I got mine this summer and it is great!!
Old 11-13-2006, 04:38 PM
01_ram-air's Avatar
Stock motor here with 4000 stall converter. You don't need a cam to get a TC.
Old 11-13-2006, 07:58 PM
Gilbert@Ace Racing's Avatar
Think about it this way... camshafts by design make power in different RPM ranges... a good torque cam typically will begin to make power around 3k to 4k RPM, or the "bottom end". A good high H/P cam goes to work around 4k and up "the high end".... pick a converter that stalls at or near your engines power range. If you choose a high stall converter you will also need a cooler... converters generate tons of heat during stall.
The key is to pick a converter that suits the engines capabilities.
g
Old 11-13-2006, 09:09 PM
I8URLS1's Avatar
So go for an 8 inch 5500 like I used to have hahaha... I think you'd love a 3500. My friend put one with with just bolt ons and loved it and with his torquer cam now he REALLY loves it.
Old 11-14-2006, 01:01 AM
DOUBT IT's Avatar
I'm absolutely sure that you need a cam if you have a stall, because what else would operate your valvetrain? Sorry, I had to...
My SSF4000 pulls just fine with the stock longblock as sent by GM. See sig for times...
Old 11-14-2006, 08:10 AM
Mohammed's Avatar
good one
btw , nice numbers
