ls2 intake on a ls1
Old 11-13-2006, 04:28 AM
pcsmits's Avatar
Default ls2 intake on a ls1
was eyeing my friends intake off his goat and was wondering if these can be swaped on to a ls1 it looks like all that would have to be done is to fab an adapter for the throttle body and use that style fuel rail any one know if this is possable
Old 11-13-2006, 10:39 AM
1slow98Z28's Avatar
u can do it i believe there is NW trottle body that will adapt to it. And the Ls2 is a 90mm i believe
Old 11-13-2006, 11:33 AM
bjamick's Avatar
yes the LS2 will fit just fine but i believe the LS6 is the better of the 2. Also the LS2 intake i believe is an 85mm..
Old 11-13-2006, 11:47 AM
lastcall190's Avatar
https://ls1tech.com/forums/showthrea...ght=ls2+intake
Go with LS6, cheaper in the long run it would seem
-J
Old 11-13-2006, 02:35 PM
Justin00SS's Avatar
You can't cheat the system.
If you want a badass 90mm setup you are pretty just gonna have to buy a fast or some other aftermarket intake.
Old 11-13-2006, 03:36 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
FAST FAST FAST
Old 11-13-2006, 03:59 PM
pcsmits's Avatar
thanks for the info ill look for the ls6
