Flat black, OEM black, or black with a twist?
This winter i will be prepping my car to repaint it.. it's GM OEM black Z28.
Up until recently i was just gonna paint it black again.. but now im considering some options. I just saw a SATIN black dick harrel camaro in a thread and thought it looked actually pretty good. Then one of my buddies suggested maybe black but with... not sure on what its called but metallic hue or flakes or something like that. I also saw the pictures of the LS7 GM performance parts camaro with the satin black finish which i really liked. I like the look because it is kind of sleeperish yet still good looking. Plus my car is a daily driver and I've been led to believe that satin black shows less signs of wear and what not.
As far as other appearance mods... right now just 17 x11 ZR1's.. sitting in my garage waiting for the car to be painted before going on a billet grille... stainless steel CAMARO lettering for the back and no badges. I am considering a Harwood wide cowl hood and most likely SS spoiler. I might throw a retro Z28 badge on the front grille...
Opinions.. pictures.. suggestions.. anyone?
ALso for all you body work gurus.. if my bumpers are spider cracked... will that be hard to prep for paint.. will i have to strip them down completely.. i dont want to buy new bumpers i know how expensive they are.
i think the satin black would look ok, but i wouldnt do any metallic flakes on a flat/satin paintjob. If you did oem black it would look good, but otherwise dont do it. everything else you mentioned sounds good too
Just an Idea. If you have a real good painter. maybe a black metallic using gold metallic. Had a 79 supra that was painted that and it looked super when cleaned up.
Restricted User
Originally Posted by Magnet
i don't think it will look good unless you have the car setup perfectly, otherwise it will jsut look like its in primer and or is a crappy paint job
