OK I'm cornfused here
Old 11-14-2006, 02:37 PM
S10Northwest's Avatar
Default OK I'm cornfused here
I have a 2000 Sonoma 4.3L I want to put the LS1 fans in it so I can get rid of the Clutch Fan, how do I wire fans into this truck, where to put relays etc also how many relays etc and whats a good temp sensor that say comes on @ 185 and goes off @ 170
thanks
Old 11-14-2006, 03:24 PM
bczee's Avatar
You can alway go standalone.. SPAL (and others) makes some fans controller or thermostats Kits to turn on fans at 185 or 195.
Old 11-14-2006, 05:02 PM
philntx's Avatar
Default Fans
Why not go with a Flexalite Black Magic 160, since you're just cooling a 4.3?
Cheaper, probably easier to install, and readily available.
http://www.flex-a-lite.com/auto/html...c_s-blade.html
Old 11-14-2006, 06:40 PM
I already have a set of LS1 fans so I'm not gonna mess with the above.....but thanks anyways
Old 11-14-2006, 11:04 PM
sawzall wielding director
G-Body's Avatar
You would need 2 relays (one for each fan, since I am pretty sure that the LS1 fans will draw more than 30A). You would want to wire them up as a single speed unit.
Old 11-15-2006, 09:06 AM
shifty`'s Avatar
If you need a pair of adequate fans, I have some fans I bought on eBay that I'm not going to use. They're out of a '97 Iroc, one is newer than the other, but both are functional.
I can take pics if the interest is there. I was going to wait until my swap was done before selling off all my spares (I have lots of other crap to go also).
Quick Reply: OK I'm cornfused here
