Blower Cars, what stall speed you running?
Old 11-14-2006, 04:38 PM
Ed Blown Vert's Avatar
Default Blower Cars, what stall speed you running?
Since I have my Vig 3200 converter out of the car. I was thinking about restalling it to a 3600.
Not high enough? Or should I just keep it where its at, given my power level.
Old 11-14-2006, 04:59 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Converter business is pretty tricky. Sometimes you get it right, other times you get it wrong. I am finally happy with my Yank PY3400. Your best bet is to find someone with the converter you are looking at and go from there. Or if you are happy with your current converter keep it.
Old 11-14-2006, 05:27 PM
Got Me SOM's Avatar
i run the same converter, pro yank 3400. I used to have a 3800 that was way too much. wish the 3400 could flash to 3600 but i'm very happy with this converter it hits harder, holds the flash, doesnt slip and drives like stock until you hit it.
its good for 1000 hp too, now i gotta make more power.
Old 11-14-2006, 06:26 PM
eb02z06's Avatar
I'm almost 99% sure i'm going with a PY3600. It has a lower STR so it doesn't hit the tires as hard. A guy over at the CF forum just ran 9.70@141 mph with this converter with a forged 346 and ECS Paxton kit which makes around 740 rwhp. I remember when I got my first stall for my 98 camaro. I got the 3200 vig-it hit the tire so hard that I wouldn't 60 ft at all-then I swapped to a Yank and the hit was much softer plus I gained about 2 mph on the big end.
Old 11-14-2006, 06:53 PM
Got Me SOM's Avatar
run the bigger str and get a stickier tire. 1/4 mi is all about the first 60 ft and 1/8 mi.
when you start making those crazy hp numbers it really comes down to suspension.
man i'd keep your car a stick and have fun banging those gears.
Old 11-14-2006, 07:04 PM
JMBLOWNWS6's Avatar
Pro Yank 3400 I love it!
Old 11-14-2006, 07:17 PM
WHPLASH's Avatar
I agree with all of the above. I love mine compared to my old Vigilante.
Old 11-14-2006, 07:46 PM
I don't have any issues with traction running this converter and ET Drags, that why I was thinking of upping the stall some to get into boost sooner. I just don't want to blow through it.
Maybe I should wait and get a D1 installed first.
Old 11-14-2006, 07:57 PM
Fly to Texas and drive my car with the PY3400. Then at the end of the year you can claim it as "research and development costs."
Old 11-14-2006, 08:02 PM
Got Me SOM's Avatar
Ed see if they can loosen up the pro yank 3400 to a 3800 while keeping the 2.5 str.
with your spray and boost this should be the right converter for you man.
with et drags you should be able to yank em up with this converter. IT GRABS.
Old 11-14-2006, 08:52 PM
eb02z06's Avatar
Bro-you don't know the carnage that happens when the tire "dead hooks". Output shafts, short shaft-long shafts and then the re and re to put it all together-it's just a pain. I think the PY3600 will let you either use eT streets or ET Radials-imagine drive to the track 100 miles on ET Radials-air them out and run 9's-then pump them up and drive home.
Old 11-14-2006, 09:19 PM
Well so far I have been lucky with my stock rear.
*knocking wood*
Old 11-14-2006, 09:21 PM
Dbluegoat's Avatar
man i love my vig3200
gone as low as 1.51 with it and the blower w/o the spray
Old 11-14-2006, 09:24 PM
eb02z06's Avatar
Ed get the D1 first bro-the D1 over the P1 is a real kick in the pants-I couldn't BELIEVE the difference when i swapped this summer.
Old 11-15-2006, 11:13 AM
Got Me SOM's Avatar
LOL if you're worried about your IRS man you shouldn't be running your car as a drag car! A lower str will help some but still that's still gonna beat hard on that rear. Throw a 9 inch in there.
Old 11-15-2006, 11:16 AM
I think that is what I will do. I guess I can drop the tranny again. If I decide to swap.
Old 11-15-2006, 12:13 PM
eb02z06's Avatar
Put it this way Ed-when I went from the P1 to the D1 I went from a 4" to 4.10 pulley-so I went up in pulley size. I picked up 52 ft/lbs or torque-and get this-I dropped my timing by 1 degree and add losts of fuel-my AFR was 10.1 and I still gained 52ft/lbs-the difference is sick!
Old 11-15-2006, 12:18 PM
Can't wait. Now someone sell me one.
And to think I run a 3.0 pulley
Old 11-15-2006, 12:23 PM
eb02z06's Avatar
Ed I might sell mine soon and step up a F1A, there's a guy on the Mustang Corral who had one too-I think he wanted like $1500?
Old 11-15-2006, 12:29 PM
I thought the Mustang version spins the wrong way?
If the price is right I am ready to buy.
Quick Reply: Blower Cars, what stall speed you running?
