Honest opnion about 2 exhaust options
Either i will go with long tube headers with off road y pipe with cut out and the gmmg cat bacfk exhaust... Or the long tube headers with x pipe and mufflers with turn downs. the horsepower should be about the same but what would be a better option for sound .
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
If you are lowered the Y + GMMG will probably be better, although it seems there are many with duals and dumps...guess it depends on where you live and what type of roads there are .....I love the gmmg myself..thinking about getting one....Sound is VERY subjective.
oh, and i dont care for the dumped sound. the y/gmmg will sound better to me
dumped is very loud and rattles a lot of things (and yes, my TDs are still very loud, but its a different loud, ones annoying, the other not so much)
Also the setup you propose will be fairly loud. Sure opening the cutout will make it louder, but it will loose sound quality over the GMMG. And plus most of the noise increase will only be in the car as the cutout will dump under the car.
BTW - more than one person has said the GMMG sounds raspy with an ORY and certainly sounds better with CATS. If you really want to run an ORY then maybe look at the Stainless Works Chambered exhaust, it's very similar to the GMMG but has sligtly more muffler lenght, this should make it sound better without CATS. Or do a search in this forum for Powerpack.
Either way I say don't bother with the cutout, well at least at first. If it really isn't loud enough for you, you can still have the cutout added later for no extra total outlay.
On the whole however duals can sound better, but there are a lot of horrible sounding setups (muffler dependant mainly). And there are certainly a lot of good sounding Y pipe setups.
For sound I personally prefer a H pipe setup. It is in reality just as good for power. Maybe not quite as good PEAK as an X pipe but generally better under the curve performance. But it does offer a deeper old school muscle car sound compared to the more exotic revvy sound of an X pipe.
I'd also consider running chambered mufflers like Powersticks or Stainless Works chambered mufflers. Another popular option is 10 Series Flowmaster mufflers.
