How many of you guys drive your lt1 without letting it warm up?
Like the title says, whenever its pretty darn cold outside, do you guys run your car cold without letting it warm up? I sometimes run a little late to college and have to do that sometimes.
my car is done for the year and put away but regardless i always let it run for 5-10 minutes before i drive it to let everything get oiled good and some heat to build up in it and i dont run it hard until its at temp
I give a minute or two and then go, but I drive real easy on it for five minutes after that. I learned my lesson last time on my monte where I started it up cold when it was 20 degrees out and did a burnout down the street. Then I wondered why it smelled like anitfreeze, apparently I blew out the gasket on the waterpump
Originally Posted by infinitebird
Yeah, there's really no need to let it warm up as long as you don't rev it really high when it's cold.
If i shiver before i get to my car i let it sit for a minute or two, but usually i just get in and go. I lay off the throttle though.
Also i guess if you count me starting the car then finding a radio station then putting my seatbelt on as waiting....then yes i wait.
