How common are spun rod bearings?
Old 11-15-2006, 01:33 PM
jeremy341a's Avatar
Default How common are spun rod bearings?
How common is it for an LS1 to spin a rod bearing before 100,000 miles? My old 98 spun one at 87000. I am looking to buy another LS1 and was getting curious. How many out of 100 would you say spins a bearing before 100,000 miles.
thanks
Old 11-16-2006, 12:46 AM
screamin86's Avatar
i would say it depends on how it was ran adn kept up. my 96 civic i had spun a bearing at 74k damn hondas
Old 11-16-2006, 08:52 PM
BLKWS.6's Avatar
Well, 98's had the funky oil pump...
Old 11-16-2006, 09:20 PM
dlc1609's Avatar
my '98 spun one at 135k....
Old 11-16-2006, 09:44 PM
brad8266's Avatar
I just threw a rod this morning at 98K, threw it upon startup of the damn thing this morning. I dont know what the hell happened.
Old 11-16-2006, 10:00 PM
BLKWS.6's Avatar
Holy crap, what oil are you guys using?!
Old 11-17-2006, 07:28 AM
brad8266's Avatar
mobile 1 5w30
Old 11-17-2006, 07:38 AM
98 T/A raptor's Avatar
My 98 is fine at 92,000 the last 10,000 I have been rough on it witha 150 shot and well I drive it like I stole it
Old 11-17-2006, 07:52 AM
screamin86's Avatar
My 86 with its original motor lasted till 217,3xx then it spun one. they just dont make em like they use to....all underpowered and such
Old 11-17-2006, 07:53 AM
Tech Resident
WhiteKnightZ28's Avatar
LS6 oil pupm FTW!
Old 11-17-2006, 08:07 AM
JeepinBash's Avatar
yeah i have heard of alot of the early years spinning a bearing. mine had one when i bought it and it was a 98.
Old 11-17-2006, 12:45 PM
777's Avatar
Most if not all spun bearings come from people not running enough oil. Spinning the engine way on up there 7000rpms+ and stock oil pump failure. Get a new oil pump, make sure you have oil and don't spin past 6500rpms and you should be fine for a long time. I have a perfectly smooth engine and I have 115,000 miles on my car and it's been cammed for many of those miles.
Old 11-17-2006, 12:48 PM
jeremy341a's Avatar
My car was bone stock, always had the proper amount of oil, mobil one. That said I can not vouch for the previous owners who had the car from birth to 78000. So I can not refute your statement.
Old 11-17-2006, 01:11 PM
Tech Resident
ChocoTaco369's Avatar
Originally Posted by brad8266
mobile 1 5w30
welcome to the long term effects of 20 weight oil protection in a high clearance V8. pair it with mobil 1 5W-30's poor consumption protection and you get...a spun rod bearing
fix it and run a better oil and i bet it won't happen again...at least for a long time.
Old 11-17-2006, 09:19 PM
silverLS199's Avatar
so 30weight is not good in these motors
Old 11-17-2006, 09:50 PM
JKDZ28's Avatar
Mobil 1 is too thin.
Try a better oil like German Castrol 0-30
Old 11-17-2006, 09:51 PM
KrazyDan's Avatar
If you search, you will find out, Mobil 1 10-30 is more of a 20wt oil. The "best" oil out there is german castrol 5-30. Most people dont have access to it so they run with M1 0-40.
Old 11-17-2006, 10:04 PM
Tech Resident
you mean german castrol 0W-30, not 5W-30. their 5W-30 is not as good as their 0W-30, and i think the 5W-30 is only available at BMW dealerships or something.
GC 0W-30 isn't perfect, either. some people experienced increased piston slap, but it seems to vary based on LS1's. some get it, some don't. the protection is impeccable, however. i get a little cold start tick on GC 0W-30, so next batch i'm gonna try mobil 1 5W-40. they're the only two oils i'd consider running in an LS1 assuming i can find them both. mobil 1 30W's have the protection of water in these high clearance engines. it's like pissing in the crankcase. mobil 1 0W-40, i'm not the biggest fan of as it's a mainstream oil. mobil 1 0W-40 still shears more easily than GC 0W-30 and mobil 1 5W-40, but all their mainstream oils are compromised. still, if you can't find GC 0W-30 and mobil 1 5W-40, mobil 1 0W-40 is a good choice by default. also, consider shell rotella synthetic 5W-40 and amsoil 5W-40 if you have the cash - but only if you can't find GC 0W-30 an M1 5W-40.
Old 11-17-2006, 10:07 PM
5_02ls1's Avatar
98 153k castrol syntec 10w30.it gets rode hard and put up wet every time out.
Old 11-17-2006, 10:21 PM
1998z28ss's Avatar
People are entirely too picky about their oils. I can almost guarantee that using the factory recommended oil is not going to damage your engine. My father has been building motors for the better part of 40 years and he swears by the cheapest oil you can find. As he says they all have to pass the same SAE specifications in our country. I've ran castrol syntec 10-30 in mine for a while and now I switched to M1 10-30. We'll see how it pans out.
Quick Reply: How common are spun rod bearings?
