Crate Engine First Start Procedure?
I bought an LS2 from SDPC, Im getting ready to install it and im just curious what all needs to be done before the first start up? How do i make sure its all oiled etc? Any procedure or checklist to follow? Thanks,
John
John
Leave the white connectors on the coil packs dis-connected, turn the car over for about 5 seconds or until the oil pressure gage starts to rise. Plug the connectors back in and fire the car up, bring the RPM's up to around 2,000 RPM's for about 15 minutes while watching the oil pressure and temp gage. That will get the motor lubricated well and allow the proper breakin time.
Kleeborp the Moderator™
Originally Posted by MeentSS02
Holding the gas pedal to the floor while cranking it over has the same effect...no need to disconnect the coil packs. It disables the injectors...
I didn't know that, cool, thanks! Learn something new every day.
