Fueling & Injection - Problem between injector and PCM!!
Dmoney
11-30-2001, 11:22 PM
My car started trembling about 2 weeks ago, so I took it to the dealer to see what's up.
Find out that 2-4 spark plugs are shot. Fixed, then the #8 cylinder is shot. The tech tells me it might be the injector, so they replace it and it is still not running the way it should. Then they tell me it's not the injector, that it has to with my PCM. He told me that tere is some kind of misfire communication problem with injector and the PCM. Now if it is the PCM, do I send it back to ED Wright to reprogram it. THe tech said that their scanners couldn't tell what was wrong due to all of the modifications that I have had done to the PCM. <img src="images/icons/mad.gif" border="0">
Cool28
12-01-2001, 04:46 PM
Hmm someone should ring in so. I would say call ed wright and see whats up.
Dmoney
12-02-2001, 12:56 AM
CAN ANYYYYONE HELP OUT!!!!!
Dustin Butts
12-02-2001, 08:22 AM
You didn't give a lot of info on your car. What year it is how many miles, did you get it used etc...How long have you been running the H/C setup? Your injectors could be shot... They won't take going static forever and if someone before you ran dry N2O or if you've had the H/C for a while on stock injectors they could be worn out. Get bigger new injectors and a better fuel pump and you oughtta be OK.
Mike Sorrentino
12-02-2001, 09:38 PM
If it's only 1 injector, maybe there's a wiring problem? Something could've been damaged during the H/C swap. See if the injector is getting a signal.
Dmoney
12-03-2001, 12:12 AM
[quote]Originally posted by Dustin Butts:
<strong>You didn't give a lot of info on your car. What year it is how many miles, did you get it used etc...How long have you been running the H/C setup? Your injectors could be shot... They won't take going static forever and if someone before you ran dry N2O or if you've had the H/C for a while on stock injectors they could be worn out. Get bigger new injectors and a better fuel pump and you oughtta be OK.</strong><hr></blockquote>
I bought the car new. It's a 99 T/A with 37000 miles. I've had this setup for about for about 6 months now. The tech told me the injectors were fine. All except the #8 cylinder,so they replace it and it's still doing the same thing. Now the tech down here seems O.K. I mean he's the only one that works on LS1's. Their scanners aren't telling me shit. They say I've deleted alot of the codes outa my PCM. They just tell me that it's still misfiring. Now it's drivable but I gotta know for sure before I drive it 4 hours to Houston(MTI) to get any thing replaced or send off my PCM to ED WRIGHT to see if he can fix the communication problem if it is the PCM.
