What spark plugs for a naturally aspirated 415 ci?
Old 11-16-2006, 01:51 PM
9 Second Club NA
Dragaholic's Avatar
Default What spark plugs for a naturally aspirated 415 ci?
I'm building a naturally aspirated 415 ci L92. This will be max effort drag only setup. I ran the popular NGK TR-55s with my old setup, which was a practically stock engine. I'm sure with the new setup, will require a different plug. What do you suggest? Thanks.
Old 11-16-2006, 05:47 PM
JBM
JBM's Avatar
Compression ratio? Timing?
Old 11-16-2006, 11:37 PM
9 Second Club NA
Dragaholic's Avatar
I haven't decided, but I'm thinking somewhere between 11-13:1. As far as timing, not sure until I get it strapped to the dyno and see where it makes best power at. Does that help?
Old 11-17-2006, 12:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
This isnt going to be a pump fuel motor then. I assume like VP's C12 or C16?
Old 11-17-2006, 12:22 PM
9 Second Club NA
Dragaholic's Avatar
Why is 11-13:1 too much compression for 93?
Old 11-17-2006, 12:35 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
13? oh yeah
Old 11-17-2006, 02:07 PM
JBM
JBM's Avatar
11:1 and 13:1 are miles apart in terms of tune and required fuel.
Old 11-17-2006, 02:22 PM
dailydriver's Avatar
Great LSxx tuners can do some amazing things on pump gas nowadays, but 13:1 might just be pushing it a little too far, even for their genius.
Old 11-17-2006, 03:47 PM
9 Second Club NA
Dragaholic's Avatar
So what's the max compression that can be used on 93 unleaded pump gas?
Old 11-17-2006, 05:10 PM
Grimes's Avatar
You can run more compression if you use a cam with a lot of overlap; your dynamic compression ratio will usually be lower with a bigger cam - i've heard to shoot for high 8:1 DCR.
In terms of just static compression, probably keep it below 12:1
Old 11-19-2006, 01:44 PM
9 Second Club NA
Dragaholic's Avatar
So I guess I need to wait on plugs until I decide what compression I'll be running. I didn't know that had anything to do with it. Thanks for the info. When its decided, I'll update and then we can go from there.
Quick Reply: What spark plugs for a naturally aspirated 415 ci?
