Question about venting a carbed LS1
Just started my car last night and it is making an awful high pitched squealing noise that is a vacuum problem. I have the pcv going to the back of the carb. and T-ing off of that going to the other valve cover. The other vent tube on the pass. side valve cover I capped off. I need to some how vent this motor some how, do I just run a breather on the valve cover or how are other people doing this. Please let me know.
Usually people run a breather on one valve cover and aPCV in the other. At least on traditional V8's. I don't see why this wouldn't apply to LSX's also. I know on the stock engine the two vents run together and then into the throttle body.
You could (A) run a breather in the capped valve cover or (B) run the two vents together into the carb.
When I was much younger I ran a Gen I engine with a push in cap in one valve cover and a PCV in the other. Later while tooling down the highway...Pop, Ting ,Ting, Ting. Blew the cap right off the motor and sprayed oil in the engine bay what a mess.
from what i read here, the LS1 needs vented well. it has been claimed that ls1 motors will blow by pretty quick under crankcase pressure. the other problem is oil use from pvc venting the valve covers, claimed oil misting. I can't confirm any of this. my conversion has seen any miles yet. I did read twin breathers and the valley only under pcv valve works and resolves both issues. again, i can't confirm it...
i run one breather on the pass side and ran a hose from the pcv on the drive. side to the tube on the pass valve cover my brake booster is ran in to the back of my carb.
i put a small import type breather on the tube on passenger side valve cover and ran hose on driver side to back of my intake on carbed 6.0 with a victor jr. seems to work so far?
for carb'd, id cap off everything and run a breather where your oil cap runs.
i know some guys run a line from valve cover to valve cover, but the pressure will release either way.
wagner(WAR) has a nice valley pan with a stand that will accept a clamp on filter. i might go with one while ive got my intake off.
