F.I. guys with 1000-1200hp fuel set up???
Old 11-16-2006, 11:13 PM
jv_Z28's Avatar
Default F.I. guys with 1000-1200hp fuel set up???
Hey guys. I have a 98 camaro and I need to put together a fuel system that will support 1000-1200 hp. Is there anyone out there with this amount of power that can help me out? thanks.
Old 11-16-2006, 11:33 PM
JMBLOWNWS6's Avatar
Get your 98 tank sumped. Run a -10 AN line with a y to any fuel rails you wish to buy and run a return back to the tank with a bulkhead fitting. Get a magnafuel 4303 or a areomotive pump to handle the fuel demand. Pick you own fuel regulator and get a electric fuel pressure gauge.
Old 11-17-2006, 12:28 AM
jv_Z28's Avatar
why an electronic fuel pressure regulator? and what size aeromotive would handle that?
Old 11-17-2006, 04:44 AM
EPP
EPP's Avatar
Smile Fuel System
http://www.exoticperformanceplus.com...Car.php?car=42
Check out the fuel system that we installed on this '98. I have the Aeromotive part numbers that were used listed. Bob
Old 11-17-2006, 04:49 AM
LS2Camaro's Avatar
Of course do not forget about the larger injectors, im going with 96lb/hr. I went with the MagnaFuel 4303, rated up to about 1400rwhp. You will need either an aftermarket Computer system, i went with a Fast XFI or the Converter Box that will allow you too run larger fuel injectors which is a must at that level of horsepower. To make it easy check out Nasty Performance Site http://www.nastyperformance.com/FuelSystems.html I went with the Stage 2 Street/Race Kit that came with everything I needed.
Old 11-17-2006, 07:08 AM
MIGHTYMOUSE's Avatar
i run a stock 98 tank, twin walbro 255's w/ dedicated relays on the stock sending unit, -8 line out to aftermarket rails and regulator. and the retun line is the stock pressure line, 96# injectors
Old 11-17-2006, 07:50 AM
Tiago's Avatar
word
Old 11-17-2006, 05:04 PM
TrakDay's Avatar
I just got all my stuff other than the fittings...
Weldon 2025 pump
-12 feed to pump
-10 feed to Y block
-8 feed to rails from Y block
-8 return line
Nasty Nate Sumped tank for GTO
Pre and Post Filters
Aeromotive Pro Series Fuel Pressure Regulator
Aeromotive Fuel Rails
160# Injectors
Big Stuff 3
Now I need to decide how I want to plumb the entire system and order my fittings!
Old 11-17-2006, 05:28 PM
gator's 99TA's Avatar
why isnt stenod doing this for ya mick?
Old 11-17-2006, 08:14 PM
TrakDay's Avatar
I am saving money on stuff I know how to do. But with the recent sale of my house they will most likely end up instlaling it anyways.
Old 11-20-2006, 11:19 AM
Nasty N8's Avatar
I have complete feul systems for your needs. We can custom tailor it for your needs give me a call.
Nate
Old 11-20-2006, 11:42 AM
JMBLOWNWS6's Avatar
Nate
LOL But if you want to go heavy hitter style there always Nate! Thats what I am using
Old 11-20-2006, 03:46 PM
Nasty N8's Avatar
Well I would say 1000-1200hp is pretty heavy???
Old 11-20-2006, 04:34 PM
JMBLOWNWS6's Avatar
Yea it is Nate. Sorry I missed ONE thread that I didnt reconmend your systems too LOL Im about to test the system you sent Jessie. Ill see if I cant max out this 4303!
Quick Reply: F.I. guys with 1000-1200hp fuel set up???
