Stereo & Electronics - Stock radio code
SCP_Racing
11-17-2006, 06:52 AM
Hey I have a 2000 trans am and wondering if anyone knows the master code to unlock the monsoon radio.
Formula350
11-17-2006, 08:24 AM
Did a quick Google and came up with this. Good luck
http://www.z28.com/forum/showthread.php?t=84182
WhiteBird00
11-17-2006, 03:08 PM
That procedure is correct but the codes are outdated - try this one (http://www.ls1tech.com/forums/showpost.php?p=5270330&postcount=2) instead. Where it says the "button" it means the star button - it just didn't display properly.
There is no "master" code to disable the radio TheftLock system.
Z28LS1camaroguy
11-18-2006, 12:43 AM
or isnt it in the owners manual???
WhiteBird00
11-18-2006, 08:37 PM
The instructions in the owner's manual assume you know the code you used to lock it in the first place. If you don't then you need to use the dealer's procedure as detailed above.
SCP_Racing
11-21-2006, 07:09 AM
hey thanks guys
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
