Keys stuck in ignition...HELP!!!!
Drove my 93 TA to work went to turn the car off and the key wont go back to the position so I can take it out. I can start the car...but the key won't rotate all the way back, kinda in the middle position...any thoughts on what to do? thanks.
A4, right? The linkage of this shifter is not going to where it should and not releasing the selenoid, happened to me, and I freaked out too.
Push pull on shifter and it will eventually release.
It happened in my 94 when I wedged the scanmaster btween the console/tape holder and the bottom of the radio, it misaligned stuff, removed the scanmaster and all was unbound.
The keys are out now...I wiggled and moved everything and they came out...thanks guys! Is there a fix for this? Is the interlock actuator not working right? Ormaybe a miss alignment issue...can anyone run through the steps.
