Water Temp guage at 200.
Quick question. I'ved had my car for a year and some months, My temp guage was at 160 and now it's reading 200. I recently flushed the radiator and I'm still seeing my temp at 200. I'm not leaking any water on the radiator or water pump. Any ideas? Should I be worried?Thanx!
__________________
__________________
Has Unresolved Sales In Feedback/12 second club
Does it have a aftermarket thermostat? The factory ones were set for 210-215? if it doesent get any higher than 200 i wouldnt worry about it. thats the norm.
Stock gauge? Just below 210 after warmed up is normal when warm on 99's and up - mine's always been that way even with a 160 tstat and lowered fan temps.
Starting in 1999, the gauge was really a dummy gauge. It should read somewhere in the middle for normal operating temp. The 210 mark is normally between 180-220 I believe. This is perfectly normal. 160 could have meant your car was at like 175. I wouldn't worry about it. Only worry if it reads up in the 3/4 gauge area.
Originally Posted by TheLS1Kid
its a dummy. i have a 160 degree thermo and cooling fans and the needle hangs out just below the 210 mark when warmed up. dont worry about it
Originally Posted by notatruews6
really? damn ive got a stock t-stat, adjusted cooling fans and it still reads 190-195?
