Max boost with a 98 PCM?
Flossin' twin turbos
Originally Posted by FormulaFire
You have several options.. HP Tuners 2 Bar... which give you up to 14.7psi... there's several 98 pcms running custom 3 bar setups.. And there's always BS3..
ive been runnng a stock 98 pcm for a year @ 11-14 psi on a stock engine. Its been as high as 18-19 but I ussually run 14 on 91 octane with water/meth. Right now it has a leak and has been running 8-9 for a couple weeks. I did toment a c5 last nigh though and a ram air ws6. The c5 was for miles, it was funny.
Originally Posted by BLWN1
Care to explain or point me in the right direction?
NASTY used the MAF- T Pro.. not that expensive. I believe Fcfd98 uses a custom 3 bar.. Just do a search.. Several guys have done it for years.. Because there was no other alternative really.
