what are 42lb injectors good too
Will be H/C/I in a few weeks and looking to be around 465 NA. I know duty cycle on that will be getting high. I have a walbro 255 that I will be putting in very soon. I also will be spraying a 100 shot on top of that so I want to know if 42lb injectors will be ok with that set up. Should see high 500HP numbers. Thanks
I heard the svo 42's are good for around 530-550 rwhp on a supercharged car. I would think you could get more hp out of them with your setup. No Idea how much more tho.
Hope this helps.
Hope this helps.
9 Second Club NA
Also, you have to know whether that injector was rated at 42 lbs. at our fuel pressure rate or Fords. Because a SVO 42 lb. fuel injector is really around 47-48 at our pressure.
The LS7 injector is 40 or 42, but again, that's at our rate. So a LS7 40-42 lb. injector will support less power than a SVO 42 lb. injector because its really 47-48 at our fuel pressure rate.
9 Second Club NA
At a 15% drivetrain loss, which is a good estimate with a TH400, big stall (I assume), etc. would put you at 563 to the motor. It may even be more depending on your drivetrain setup. With mine, there may be an even bigger loss as I have a TH350, 5500 stall, steel driveshaft, 4.56 gear (spool), and 30" slicks.
((((((Administrator))))))
CRAGER, any idea what the duty cycle is on the SVO 42s?
Peace,
Craig.
