how about these specs for a custom cam...
Old 11-19-2006, 07:38 PM
66deuce's Avatar
Default how about these specs for a custom cam...
i was playing around with the VE calculator and came up with this small cam for a DD,346CI motor. cam gurus,tell me what you think. XER lobe on the int.,XE lobe on the exh.
220/220 .581/.564
113 LSA 111 ICL
-6* overlap
cam should have a broad power band,peak around 6000rpms,and a smooth idle. any thoughts?
Old 11-19-2006, 07:49 PM
pist0lpete's Avatar
Thats a pretty small cam and I can't expect you would see much power increase over the cam in your sig. Unless you are just experimenting for fun I feel you would be disapointed unless you went with something bigger.
Old 11-19-2006, 08:15 PM
66deuce's Avatar
yeah,i was just playing around after looking at some dyno runs with smallish cams.for somebody that wanted to go with a small cam for a street/strip application,i would think it would be a good compromise between peak numbers and area under the curve...
Old 11-19-2006, 08:19 PM
JoeyGC5's Avatar
what about a 220/224 .596/.588 111 lsk/xer
Old 11-20-2006, 02:46 AM
66deuce's Avatar
that would work as well.or how about a 218/218 XER 109 lsa....i wonder if anybody has tried these smaller cams on a lower lsa?
Old 11-20-2006, 07:10 AM
YankeeVert.'s Avatar
I don't think you can get the XER lobe on any duration less than 220*.
Old 11-20-2006, 07:34 AM
Banned - Ed Curtis aka EDC
LSX-Racer's Avatar
Have you seen the small cam packages over at LS1GTO.com?
Old 11-20-2006, 11:32 AM
Link Please
Old 11-20-2006, 03:08 PM
66deuce's Avatar
no,i'll have to check them out,thanks....
Old 11-20-2006, 03:10 PM
66deuce's Avatar
Originally Posted by YankeeVert.
I don't think you can get the XER lope on any duration less than 220*.
really?i thought you could.i'll check my catalog out...
