Stereo & Electronics - Interior Light Question
01 Red WS6
11-19-2006, 07:56 PM
one of the lights on the door panel by the handle went out. I got a new bulb for it and replaced it but now it doesn't light up as bright as it did before. The bulb doesn't even light up the switches anymore. I had trouble getting the old bulb out as it broke while I was trying to pull it out. It left the base behind and I ened up breaking it up to get it all out. Is it possible that I damaged the socket enough to cause a voltage drop to make the light burn a little dim? I have checked and I'm using the correct bulb, #74 I think (I don't have the package in front of me)
Any ideas would be appreciated.
01 Red WS6
11-22-2006, 09:33 PM
Bump.. can anyone help me out?
XpEdItIoUs
11-23-2006, 03:26 PM
Try other bulbs I doubt you damaged anything will taking it out. if you think you damaged it and it isnt getting power to it test it with a dc/volts reader.
02TransAm/Batmobile
11-23-2006, 06:15 PM
uh oh, check your pm
01 Red WS6
11-25-2006, 10:14 PM
I changed the bulb and it still didn't get any brighter. :confused: I guess I'll have to check it out with a tester
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
