Squealing coming from Engine, power steering pump? pulley?
Well I have tried about three or four searches without any luck.
This problem started a few weeks ago when it finally started to get cold in Texas. I had attempted to wash the engine bay about a week earlier as well.
Now it seems almost everytime I start my car from a cold start (sometimes warm start), I get this awful sounding squeal coming from the front of my engine. Although it does seem to happen more often when it is cold or humid. After no longer than a minute, the sound stops. I have already spent 60 dollars on new belts. I would like the next repair to fix this problem permanently. Could my power steering pump be going bad? I notice fluid constantly built up around the top of the reservoir. I also think I read somewhere on here about washing the out the grease from the pulley bearings? If anyone has any ideas, they would be appreciated.
Thanks
Thanks
bjamick
im pretty sure it just needs a new belt bc when you washed it it prob just got the belt wet then dried it out and now thats why you have that squeak. IMO just spend the $10 and get a new belt.
If it was the AC clutch though, I thought it should whine constantly. And I had to listen to the AC clutch go out on my LT1, this sounds nothing like that.
Cooling fan bearing, really? Its a quite loud squeal (sounds like a belt squeal) and the sound appears to be coming from one of the accessories, near the powers steering pump. Could a bearing in the cooling fan really make such a noise?
how long was it squealing before it finally died? And did the squealing get worse over time? Did it only squeal when first warming up?
Not relevant but I am almost positive this is happening cause I washed the engine block. Thanks GM First Optispark on LT1, now they power steering pump on my LS1
Well, I listened to the sound again yesterday, and at start up, it sounded like I had a bird stuck under hood. Chirp, Chirp........ Chirp, Chirp...... Chirp, Chirp
I know a belt is more of a squeal, and this is definitely a Chirp. Anyone have any thoughts?
well what could it be then? it sounds like it is coming from the area near the power steering pump. is there a way to test/diagnose this to figure out what the problem maybe?
