Which power adder would you recommend?
Old 11-20-2006, 11:45 AM
nyteryder167's Avatar
Default Which power adder would you recommend?
Alright guys, I need some advice from the wise . I've been planning what I'm going to be doing next year and have come to a point I can't decide on. Here are the basics:
My car made 382 rwhp after the cam, that's where it is at now (mods in sig). I want to make >450. I will be going with a Moser 12-bolt and a driveshaft before any more performance mods. The car sees a lot of street driving (which is why I went with a mild cam) but also gets about 5 track visits each year.
Now, do I go with a turbo setup, supercharger, or nitrous? My power adder budget is around $4-5K including installation. I'm open to just about anything, so lemme hear what you guys have to say. Thanks in advance.
Old 11-20-2006, 11:50 AM
SELLSZ06's Avatar
Procharger d1, itll give most reliability and its easier to install than anything else. However look into spending at least 2k more, better done once and done right!
Old 11-20-2006, 11:53 AM
98Z28MASS's Avatar
I vote for a 100 shot of N20. 4-5K wont cover everything youd need for FI IMO.
Old 11-20-2006, 11:54 AM
98Z28MASS's Avatar
Plus you could get a kit for under a grand with all the safety components, and then coudl spend the rest on a forged 346/347 short block if you wanted to have peace of mind that it would hold together.
Old 11-20-2006, 11:55 AM
NassyVette's Avatar
I'd stay away from the turbo route if your budget is only 4-5k. If you're not doing the fabrication/install yourself, 4-5k won't even get you in the door. I'd build up your drivetrain and get a nice nitrous kit w/ accessories.
Old 11-20-2006, 12:01 PM
LS2Camaro's Avatar
I agree. That budget, definitely stay away from Turbo.
Old 11-20-2006, 12:09 PM
bowtieman81's Avatar
I would tend to agree with the above; go with a good nitrous kit, especially if you are just looking for about 450 rwhp. Heck, if you have 5k$ to spend you could get a nice set of heads and probably see 450 rwhp without nitrous.
Old 11-20-2006, 02:44 PM
Great advice guys. I was actually leaning towards nitrous due to budget concerns but I didn't want to say that in case it would sway the results. Thanks again, other comments are definitely welcome.
Old 11-20-2006, 03:36 PM
Turbo LS1 SS's Avatar
nitrous....... a nice wet kit...
MAF KIT....then ur done...
u can buy a stroker and put a maf kit on and ur set
Old 11-20-2006, 04:34 PM
7 Second Club
ty_ty13's Avatar
i say spend the money on one of these new 6.2 aluminum blocks and stroke it to atleast a 4'' stroke.... use the l92 heads and intake then go to town on the nitrous... a 125 wet kit would be fun and plenty...
Quick Reply: Which power adder would you recommend?
