Gears & Axles - Dana 60 aluminum support cover clearance issue?
Ziptie
11-20-2006, 02:03 PM
I'm thinking about upgrading my Dana 60s cover to an aluminum one. The sway bar looks like it has plenty of room on the stock cover, do I really need relco. brackets? Although, the lower panhard bar looks very close to the stock cover, has anyone had problems with that?
Scott@DrivelineSolutions
11-21-2006, 12:47 AM
You will need a tubular pan hard bar and you can get a TA cover to fit. The load bolts will need to be clearanced some but it wont hurt anything.
Ziptie
11-21-2006, 08:13 AM
So, no need to distance the sway bar?
RoastEmSS
11-21-2006, 09:37 AM
My stock sway bar/ end links fit fine with the aluminum cover, i have a tubular adj. panhard and it is close but not rubbing
Ziptie
11-21-2006, 10:17 AM
Appreciate it guys.
11-21-2006, 12:54 PM
I weld on the BMR swaybar kit and I haven't had any issues with any covers rubbing.
