View Poll Results: When I start my Procharger install should I post all the pictures on here??
Yes
27
96.43%
Hell No
1
3.57%
Voters: 28. You may not vote on this poll
Learn me how to Procharge! Please!!
Old 11-20-2006, 08:38 PM
1Hotbird's Avatar
Default Learn me how to Procharge! Please!!
Hi Im new to supercharging! I need to know everything!
I want to get a 402 Iron block with partriot Heads, I know I need a BIG fuel system, and BIGGER injectors.
I want to go with a bigger than D-1SC Head unit. I've heard people on here saying FI is expensive to get into and stay in, I understand the inital cost of getting into FI (engine,supercharge system, fuel system, building the car to handel the power, ect....) What is involved in staying in FI?? Dose a FI car need constant tuning?? If the car is built right from the beggining What is all involved in in up keep? I plan on talking to BOB at EPP about my needs just trying to do some home work first! Thanks!!!
Can you order a Procharger kit D-1SC and upgrade the Head unit?
Any tips and info would be greatly appriciated!!!! Thanks again!
Old 11-20-2006, 10:13 PM
BoostedWS7's Avatar
you will probably be gettin into an F1 or F1-R procharger with a 402 cid. u really dont want to get a d1sc kit because the only thing u can use is the bracket. (procharger doesnt make a kit for big LS1's)
The intercoolers are no good for that big of setup. too small. just the f-1 blower itself is like $3G's. id talk to bob @ epp to get this stuff. he'll hook u up with a nice front mount intercooler setup. i got mine from him.
once everything is on and tuned, its not to bad to keep up. its not as much work as a turbo car, as you gotta tinker with them a lil more it seems. but with everything else, u gotta keep your eye on things that make tons of power.
for the most part, my old setup was stock with a procharger kit and it was a turn key and drive anywhere car. no problems ever, and it was like that for 3 years. i finally rebuilt it because i wanted more power. like stock driving til u mashed it.
Old 11-20-2006, 10:15 PM
BoostedWS7's Avatar
also, u gotta move the rad support foward to accomedate the bigger blower. it wider than the d1sc
Old 11-20-2006, 10:16 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I will take 2 questions. Once tuned the car should be fine and not need further tuning. Unless whoever did it the first time did not know his job (it happened to me), or if you start messing with meth, etc. The D1SC cannot be upgraded to the next higher S/C which is the F1. Therefore plan accordingly.
Old 11-21-2006, 05:22 AM
EPP
EPP's Avatar
The F1/F1A head units use a different housing than their smaller brothers, so a P-1SC/D-1SC cannot be sent in and made into an F1 type of blower.
When the ProCharger kit is initially ordered, we can substitute an F1/F1A for the D-1SC in the kit for an approx upgrade price of $440.00.
I can also upgrade you into our front mount kit for an additional $350.00 price over the ProCharger price. Bob
Old 11-21-2006, 05:24 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=42
This car that we worked on may help you out with some additional info regarding fuel system requirements and drivetrain/suspension. Bob
Old 11-21-2006, 06:48 PM
1Hotbird's Avatar
First off Thanks for all the info, It's very helpful.
With the front mount intercooler is their any way to keep the fog lights?
With the F-1 or the F-1R is their anyway to safely put it on my stock cube engine untill I can get a 402 stroker? I do have 68cc chambers on my partriot heads? How much boost can this combination handle (I will have a nasty fuel system on it b4 I charge it)??
Can a Slp 402 shortblock handle 1000hp at the flywheel?
Old 11-22-2006, 04:17 AM
EPP
EPP's Avatar
Smile
Thanks!
We retained the foglights on one customer's LT1, but it does somewhat limit airflow. With the front cut-out, you should see enough airflow though.
You could short shift your car to keep the rpm down until you get a forged bottom end. The stock bottom end should be kept around 8 psi, we've pushed 10 psi before, but I don't recommend it. Your 68cc heads wouldn't pose a problem.
The SLP 402 isn't rated for 1000 flywheel hp, but I don't see why it can't handle it, as SLP uses the same internal components that many companies use for engines pushing a lot of power.
We've built engines at our shop that are close to 1000 flywheel hp retaining the aluminum block and factory crank. These LS engines are pretty stout! Bob
Old 11-22-2006, 05:55 AM
1Hotbird's Avatar
Bob Thanks for the info.
do you happen to have pictures of how you retained the foglights?
I want to call you to get pricing on the D-1SC Kit with the upgraded head to F-1A and I will go with the Front intercooler, also I want the custom intake hat setup that 90s over and 45s up into the fender well!!
I will try and call today but I will need about a month to get all my pennies toghether for it!!!
Old 11-22-2006, 06:04 AM
EPP
EPP's Avatar
Smile
No, I don't have any pic's of the foglights, but we reused the brackets with a little modifying.
Do indeed give me a call. 260 244-4808 Thanks! Bob
Old 11-22-2006, 07:35 PM
1Hotbird's Avatar
Thanks Bob,
I did not have a chance to take lunch today and call you. Are you open Friday? is so what hours?
Old 11-22-2006, 07:58 PM
EPP
EPP's Avatar
Smile
Thanks Bob,
Thats okay. Friday I have to go pick up a customer's car out of town. Give me a call Monday if you get a chance. Thanks! Bob
Old 11-22-2006, 09:31 PM
1Hotbird's Avatar
Anyone else have any tips?
Old 11-22-2006, 09:57 PM
For you to have unlimited budget to complete the project. Getting the Procharger is just the beginning...
Old 11-22-2006, 10:02 PM
Jake@EPP's Avatar
Aint that the truth!
Old 11-22-2006, 10:09 PM
1Hotbird's Avatar
lol Wish I could say I had the budget!!
My new slogan is;
Go Big Or Burn Rice!
Old 11-22-2006, 10:47 PM
1Hotbird's Avatar
can anyone tell me if i should or should not use my Patriot # 2013 stage 2 heads with 64cc chambers, 2.02 intake and 1.57 Exhaust valves, on a 402 iron stroker with a F-1A Blower?
should i upgrade to the stage 3s with 72cc chambers? Patriot #2019??
I would like to see 900-1000 horse at the flywheel!
Old 11-23-2006, 06:39 AM
EPP
EPP's Avatar
Smile
You going to want to upgrade to a stage 3 head for the 402 and the power level you'll going to be pushing.
http://www.exoticperformanceplus.com...php?service=66
This link may help you out. Bob
Old 11-23-2006, 09:40 AM
1Hotbird's Avatar
Once again your web sit amazes me!! Great material!!
I do have full subframe connectors, toruqe arm with relocate off tranny, Lower control arms, Pahhard bar, And strut tower brace.
The biggest mods I need now are; Fuel sytem, 9" rear & driveshaft, Blower and motor!
I just rebuilt my tranny to factory specs, so I pan on running that till it blows and getting another one made by RPM.
Can anyone think of what else I might need??
I
Old 11-23-2006, 10:08 AM
Ed Blown Vert's Avatar
My new slogan is;
Mine is "If you ain't breaking, your ain't racing."
Quick Reply: Learn me how to Procharge! Please!!
