Truck manifolds VS C5-Z06 Vette manifolds
Old 11-20-2006, 08:38 PM
STEALTH TURBO C5's Avatar
Default Truck manifolds VS C5-Z06 Vette manifolds
I'm upgrading my turbo and intercooler , and am looking to maximize flow in other parts of the system , it's a remote-mounted single turbo on my C5 Corvette . I am currently running 02 Z06 Corvette exhaust manifolds , and was wondering if there's any benefit in changing to a truck manifold , or possibly an equal-length shorty header , space is an issue , which is one reason I went with the stock manifolds originally .
Old 11-21-2006, 12:57 AM
Louis's Avatar
Mike, the truck manifolds are not a pretty as what you have now. I think the 02+ Z06 manifolds are the way to go for your setup.
Old 11-21-2006, 03:10 AM
Mr_president's Avatar
truck manis are for people who want to fab a front mount turbo kit. get some long tubes with your rear mounT!!
Old 11-21-2006, 08:17 AM
Long tubes won't fit without cutting the car up and running an air to water intercooler inside the car , I need to either keep what I have , or run a shorty to give me enough clearance between the exhaust and intercooler piping on the passenger side .
Old 11-21-2006, 08:37 AM
Coal Mining Director
onfire's Avatar
I'd keep the ZO6 manifolds for your goal.
Old 11-21-2006, 12:00 PM
427's Avatar
ZO6 manifold is much better than the truck manifold. The ZO6 just won't fit on a F-car.
Cool Car!!
Kurt
Old 11-21-2006, 04:19 PM
enginjoe's Avatar
Rear turbos spool slower with long tubes. Most of us are switching back to stock manifolds and wrapping the exhaust to keep the heat in.
Old 11-22-2006, 12:40 AM
Cool Car!!
Kurt
Thanks Kurt , I'm taking my new turbo to get the hot side hi-temp coated tomorrow , would you reccomend coating the exhaust manifolds as well ?
Old 11-22-2006, 01:15 AM
Mean Green z28's Avatar
+1 ... headers slow down the flow
Old 11-22-2006, 08:36 AM
427's Avatar
With the turbo so far from the engine, anything to keep heat in the system would help.
Kurt
Old 11-22-2006, 09:03 AM
onfire's Avatar
I would coat the manifolds and the pipes leading to the turbo inside and out....inside coating is more critical for retaining heat/velocity in the pipe....outside is more for looks, but I'd do both.
Old 11-22-2006, 10:12 AM
I'm going to coat the outside , not the inside , then I'll wrap everything .
I don't want to risk any part of the coating chipping off and going through the turbo .
Old 11-22-2006, 10:30 AM
onfire's Avatar
Use 2000 Black and no worries on the inside....That's what I'm using....cast iron rusts and flakes worse than that.
Quick Reply: Truck manifolds VS C5-Z06 Vette manifolds
