Q about injectors?
Q about injectors?
So far i have a cam + bolt on car that makes 395 to the wheels. over X mas break ill be installing 243 heads, and possibly a fast 90/90 setup.
Now my question is, is that too much to run with stock 01 injectors? would i need to get some bigger ones? if i would need bigger injectors would it be possible to run that set up for a while w/out them? any imput would be appreciated. thanks
I will guess that you will be running near 90% DC at least. I think the 01s have the larger injectors, 28.4#/hr, but even then you are pushing it. 32#/hr injectorss would be nearly ideal for your peak power demand and idle.
Originally Posted by sidewayz28
thats what i was thinking as well.. but it couldnt hurt to run on the stockers until i can upgrade huh?
